#旭日X3派首百尝鲜# 【AI健身实体机】Arduino使用MAX30102人体心率血氧检测模块在X3派上位机上的显示
一、Arduino与旭日X3派通信
1.查看X3派上python是否安装serial包
825_20220724214007.png)
2.X3派与Arduino之间通过USB进行通信
3.在终端上输入 ls /dev/tty* 出现ACM0说明两者可以正常通信
4.在Arduino上烧录代码
void setup()
  Serial.begin(9600);
void loop()
  if ( Serial.available())
      if('s' == Serial.read())
        Serial.println("HelloWorld!");
5.在X3派上测试是否能够收到信息
在终端下通过python3进行测试
最后print可以出现HelloWorld!
import serial
ser=serial.Serial('/dev/ttyACM0',9600,timeout=1)
while 1:
    ser.write('s'.encode())
    msg=ser.readall()
    print(msg)
ser.write(‘s’)会报编码的错误,使用方法encode()解决。
5B8Z~RZB06BIR_20220724220300.png)
6.权限不够,退出后终端输入sudo su进入管理员模式可以解决
!(/uploads/dataSynchronization/api/v1/static/fileData/5X(FB@HS5VN@86(G$4CJCYJ_20220724215609.png)
二、MAX30102人体心率血氧检测模块在上位机旭日X3派上的数据显示
1.MAX30102
MAX30102是一种用于可穿戴健康设备的高灵敏度脉搏血氧仪和心率传感器。
MAX30102内部集成了一整套完整信号采集电路,包括光信号发射及接收、AD转换、环境光干扰消除及数字滤波部分,只将数字接口留给用户。
2.Arduino代码
#include <Wire.h>
#include "MAX30105.h"
#include "spo2_algorithm.h"
MAX30105 particleSensor;
#define MAX_BRIGHTNESS 255
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
//Arduino Uno doesn't have enough SRAM to store 100 samples of IR led data and red led data in 32-bit format
//To solve this problem, 16-bit MSB of the sampled data will be truncated. Samples become 16-bit data.
uint16_t irBuffer[100]; //infrared LED sensor data
uint16_t redBuffer[100];  //red LED sensor data
#else
uint32_t irBuffer[100]; //infrared LED sensor data
uint32_t redBuffer[100];  //red LED sensor data
#endif
int32_t bufferLength; //data length
int32_t spo2; //SPO2 value
int8_t validSPO2; //indicator to show if the SPO2 calculation is valid
int32_t heartRate; //heart rate value
int8_t validHeartRate; //indicator to show if the heart rate calculation is valid
byte pulseLED = 11; //Must be on PWM pin
byte readLED = 13; //Blinks with each data read
void setup()
  Serial.begin(115200); // initialize serial communication at 115200 bits per second:
  pinMode(pulseLED, OUTPUT);
  pinMode(readLED, OUTPUT);
  // Initialize sensor
  if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
    Serial.println(F("MAX30105 was not found. Please check wiring/power."));
    while (1);
  //Serial.println(F("Attach sensor to finger with rubber band. Press any key to start conversion"));
  //while (Serial.available() == 0) ; //wait until user presses a key
  //Serial.read();
  byte ledBrightness = 60; //Options: 0=Off to 255=50mA
  byte sampleAverage = 4; //Options: 1, 2, 4, 8, 16, 32
  byte ledMode = 2; //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
  byte sampleRate = 100; //Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
  int pulseWidth = 411; //Options: 69, 118, 215, 411
  int adcRange = 4096; //Options: 2048, 4096, 8192, 16384
  particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
void loop()
  bufferLength = 100; //buffer length of 100 stores 4 seconds of samples running at 25sps
  //read the first 100 samples, and determine the signal range
  for (byte i = 0 ; i < bufferLength ; i++)
    while (particleSensor.available() == false) //do we have new data?
    particleSensor.check(); //Check the sensor for new data
    redBuffer[i] = particleSensor.getRed();
    irBuffer[i] = particleSensor.getIR();
    particleSensor.nextSample(); //We're finished with this sample so move to next sample
    Serial.print(F("red="));
    Serial.print(redBuffer[i], DEC);
    Serial.print(F(", ir="));
    Serial.println(irBuffer[i], DEC);
  //calculate heart rate and SpO2 after first 100 samples (first 4 seconds of samples)
  maxim_heart_rate_and_oxygen_saturation(irBuffer, bufferLength, redBuffer, &spo2, &validSPO2, &heartRate, &validHeartRate);
  //Continuously taking samples from MAX30102.  Heart rate and SpO2 are calculated every 1 second
  while (1)
    //dumping the first 25 sets of samples in the memory and shift the last 75 sets of samples to the top
    for (byte i = 25; i < 100; i++)
      redBuffer[i - 25] = redBuffer[i];
      irBuffer[i - 25] = irBuffer[i];
   //take 25 sets of samples before calculating the heart rate.
    for (byte i = 75; i < 100; i++)
      digitalWrite(readLED, !digitalRead(readLED)); //Blink onboard LED with every data read
      //send samples and calculation result to terminal program through UART
      //Serial.print(F("red="));
      //Serial.print(redBuffer[i], DEC);
      //Serial.print(F(", ir="));
      //Serial.print(irBuffer[i], DEC);
      Serial.print(F(", HR="));
      Serial.print(heartRate, DEC);
      //Serial.print(F(", HRvalid="));
      //Serial.print(validHeartRate, DEC);
      Serial.print(F(", SPO2="));
      Serial.println(spo2, DEC);
      //Serial.print(F(", SPO2Valid="));
      //Serial.println(validSPO2, DEC);
    //After gathering 25 new samples recalculate HR and SP02
3.接线
VCC----5V
GND—GND
SCL----A5
SDA—A4
将MAX30102周围用绝缘黑胶布包裹起来,避免手碰到电阻对结果产生影响
OJP~J_20220724231941.png)
4.X3派代码
sudo nano max30102_test.py
import serial
ser=serial.Serial('/dev/ttyACM0',115200,timeout=1)
while 1:
    msg=ser.read(10)
    print(msg)
5.运行代码
python3 max30102_test.py
将手放上测量心率血氧,心率可以较快得出,血氧需要等待较久。
HR为心率,SPO2为血氧,ir和red为计算的中间值。
