运行compile_perf.py编译qat模型时,遇到下面的错误
1.芯片型号:J5
2.天工开物开发包OpenExplorer版本:J5_OE_1.1.60
3.问题定位:模型转换
4.问题具体描述:您好,我在运行compile_perf.py编译qat模型时,遇到下面的错误,一时间找不到解决的思路,可以帮忙看一下是什么问题导致的,该如何解决吗?
/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/qtensor.py:1000: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can’t record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
if scale is not None and scale.numel() > 1:
/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/nn/quantized/conv2d.py:290: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can’t record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
per_channel_axis=-1 if self.out_scale.numel() == 1 else 1,
/clever/volumes/anjiaju-owner/dev/history/zone_hat/hat/models/necks/fast_scnn.py:75: TracerWarning: torch.Tensor results are registered as constants in the trace. You can safely ignore this warning if you use this function to create tensors out of constant variables that would be the same every time you call this function. In any other case, this might cause the trace to be incorrect.
input_size = torch.Tensor((x.shape[2], x.shape[3])).cpu().numpy()
/clever/volumes/anjiaju-owner/dev/history/zone_hat/hat/models/necks/fast_scnn.py:75: TracerWarning: Converting a tensor to a Python float might cause the trace to be incorrect. We can’t record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
/clever/volumes/anjiaju-owner/dev/history/zone_hat/hat/models/necks/fast_scnn.py:75: TracerWarning: Converting a tensor to a NumPy array might cause the trace to be incorrect. We can’t record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/nn/quantized/functional_modules.py:163: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can’t record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
per_channel_axis=-1 if self.scale.numel() == 1 else 1,
/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/utils/script_quantized_fn.py:239: UserWarning: operator() profile_node %323 : int = prim::profile_ivalue(%_storage_type)
does not have profile information (Triggered internally at ../torch/csrc/jit/codegen/cuda/graph_fuser.cpp:105.)
return compiled_fn(*args, **kwargs)
/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/qtensor.py:296: TracerWarning: Converting a tensor to a Python boolean might cause the trace to be incorrect. We can’t record the data flow of Python values, so this value will be treated as a constant in the future. This means that the trace might not generalize to other inputs!
assert input.q_scale().numel() == 1, (
/root/.local/lib/python3.8/site-packages/torch/jit/_trace.py:976: TracerWarning: Encountering a list at the output of the tracer might cause the trace to be incorrect, this is only valid if the container structure does not change based on the module’s inputs. Consider using a constant container instead (e.g. for `list`, use a `tuple` instead. for `dict`, use a `NamedTuple` instead). If you absolutely need this and know the side effects, pass strict=False to trace() to allow this behavior.
module._c._create_method_from_trace(
File “/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/qtensor.py”, line 1204, in __torch_function__
return wrapped_func(func, types, args, kwargs)
File “/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/qtensor.py”, line 179, in wrapped_func
return f(*args, **kwargs)
TypeError: _qtensor_requires_grad_() takes 1 positional argument but 2 were given
During handling of the above exception, another exception occurred:
File “/usr/local/lib/python3.8/dist-packages/hbdk/torch_script/tools.py”, line 72, in _trace_module
traced_module = trace(module, example_inputs)
File “/usr/local/lib/python3.8/dist-packages/hbdk/torch_script/tools.py”, line 63, in trace
return torch.jit.trace(obj, placeholders)
File “/root/.local/lib/python3.8/site-packages/torch/jit/_trace.py”, line 759, in trace
return trace_module(
File “/root/.local/lib/python3.8/site-packages/torch/jit/_trace.py”, line 1001, in trace_module
_check_trace(
File “/root/.local/lib/python3.8/site-packages/torch/autograd/grad_mode.py”, line 27, in decorate_context
return func(*args, **kwargs)
File “/root/.local/lib/python3.8/site-packages/torch/jit/_trace.py”, line 329, in _check_trace
copied_dict[name] = _clone_inputs(data)
File “/root/.local/lib/python3.8/site-packages/torch/jit/_trace.py”, line 160, in _clone_inputs
return function._nested_map(
File “/root/.local/lib/python3.8/site-packages/torch/autograd/function.py”, line 486, in _map
return type(obj)(mapped)
File “/root/.local/lib/python3.8/site-packages/torch/autograd/function.py”, line 482, in
mapped = (_map(x) for x in obj)
File “/root/.local/lib/python3.8/site-packages/torch/autograd/function.py”, line 488, in _map
return {x : _map(obj) for x in obj}
File “/root/.local/lib/python3.8/site-packages/torch/autograd/function.py”, line 478, in _map
return fn(obj)
File “/root/.local/lib/python3.8/site-packages/torch/jit/_trace.py”, line 150, in clone_input
a.detach()
File “/usr/local/lib/python3.8/dist-packages/horizon_plugin_pytorch/qtensor.py”, line 1206, in __torch_function__
raise type(e)(
when calling function <method ‘requires_grad_’ of ‘torch._C._TensorBase’ objects>
File “tools/compile_perf.py”, line 229, in
compile_then_perf(
File “tools/compile_perf.py”, line 133, in compile_then_perf
result = perf_model(
File “/usr/local/lib/python3.8/dist-packages/hbdk/torch_script/tools.py”, line 360, in perf_model
traced_module = _trace_module(module, example_inputs)
File “/usr/local/lib/python3.8/dist-packages/hbdk/torch_script/tools.py”, line 75, in _trace_module
raise RuntimeError(
RuntimeError: torch.jit.trace fail. Please make sure the model is traceable.
